speaker connectors
Discussion in 'Archived Threads 2001-2004' started by Nick L, Jan 4, 2002.
  1. Nick L
    Nick L Second Unit
    Nov 14, 2001
    283
    What do you think of these connectors?
    Worth buying or is there something better for about the same price? I'm staying away from solder on ends.
    Nick L
  2. Jim_Stu
    Jim_Stu Stunt Coordinator
    Dec 27, 2001
    134
    Nick,
    The RS 278-306A is ,almost (doesn't have the plastic),
    the same thing at $3.00 each.
    If you are using 12-14 gage, woven, stranded wire, I
    don't think you will find any better way than the
    'compression wedge' fitting design.
    I would rather re-do these every 10 years, than deal
    with solder. I have found that solder joints are very
    weak at the transition area of fine copper wire.
    JRS
  3. Nick L
    Nick L Second Unit
    Nov 14, 2001
    283
    Thanks for the tip on that. The RS ones seems to be a little cheaper and don't have any plastic on them, I think I like them a little better.
    Nick L
    BTW do you use these to connect to your reciever too?
  4. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    i also use the rat-shack connectors. i think they work great. i use the single ones for my receiver (the spacing isn't big enough on the back) and the "double-connected" ones for my speakers.
    they're rock solid in my opinion...
  5. Jim_Stu
    Dec 27, 2001
    134
    Nick,
    I use the RS 278-306A banana plugs on the:
    1) Speakers
    2) Back of the receiver
    3) On the wires that plug into the wall jacks.
    JRS
