Speaker Connections
Discussion in 'Archived Threads 2001-2004' started by Brad Gable, Dec 2, 2002.
  1. Brad Gable
    Brad Gable Extra
    Nov 4, 2002
    17
    Hi All,
    I wanted to find out if it would help/hurt/be a waste of time to tin the end of my speaker wire. I will be making all connections to either banana clips to the reciever or spades to the speakers. I am thinking this way there is no exposed wire to oxidise.
    Thanks for the help and any reponses.
    Brad
  2. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    Well... some high-end wire-building sites say to never solder your wires. In truth, you are not likely to hear any difference for HT. You might hear a difference if you have highly-accurate music speakers.
    I use banana plugs and every two years or so I cut off the ends of exposed speaker wire, strip and re-connect. I do this as part of an annual "HT cleaning".
    Since you are not connecting wires in a box that should not be touched for 10 years, I dont think solder is called for.
  3. Brad Gable
    Brad Gable Extra
    Nov 4, 2002
    17
    Sounds good. I won't bother with it then. Thanks again for the fast reply.
    Brad
