Speaker connections?
Discussion in 'Archived Threads 2001-2004' started by Rick Wilson, Aug 15, 2002.
  1. Rick Wilson
    Rick Wilson Stunt Coordinator
    Aug 1, 2002
    56
    One pair of my speakers have the compression clips that you insert bare wire into. Since I am changing all of my other connections to banana plugs, I thought I would change these as well. Is there a connector (wire end) that can be used? Is there really a need to change the connectors (wire ends)?
  2. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    For the spring clips, you can get something called "Pin Connectors". These terminate your speaker wire into a solid pin, and the pin has groves that the clips bite into so they dont just pull out. (Make sure the pin connectors you buy have these groves).
    But I have to say, for spring clips, I'd just use bare wire unless the holes are just too small for the speaker wire. I'm worried about the surface area - the entire signal is transmitted through a very small contact surface from the edge of the spring clip to the pin.
    I have used the pin connectors on my older receiver and I cannot honestly say I heard any difference between the pins and bare wire. It's just the thought of that tiny area - just bugs me.
