Speaker connection help (1 Viewer)
George Caronan
Hello all. I have bi-ampable front towers and I am not using a subwoofer due to space considerations. They are Fluance SV-10s. Will the following set-up work?
1. Connect the dual subwoofer outs of my pre-amp to an amp then run the speaker wire to the bottom pair of binding posts of my speaker for the subs. The upper binding posts for the mids and tweets will be supplied by separate channels.
2. Set the speaker size on my pre-amp to small and set the subwoofers to yes.
The amp power required for the speakers are 50-200 watts. I have a seven channel amp Outlaw Model 7100 but I am using only a 5.1 set-up. It would seem a waste not using the two remaining channels. Has anyone out there tried this manner of setup? Thank you in advance.
George Caronan
Just to add. The woofers on the SV-10s are 8" side firing. The amp wattage on the Outlaw is 100 watts per channel.
yacubjkc
