speaker calibration...receiver test tones or some specialized HT test disc?
Discussion in 'Archived Threads 2001-2004' started by Curtis_Edwards, Feb 13, 2002.
  1. Curtis_Edwards
    Curtis_Edwards Stunt Coordinator
    Jan 1, 2001
    101
    Which should you use and why? Are they both going to be the same output?
    Thanks.
  2. Greg_W
    Greg_W Stunt Coordinator
    Jul 6, 2001
    54
    It's better to use the fancy calibration disk, because this will take into account the whole system, from the laser reading the DVD to your seating position, rather than just from the reciever on. That said, the difference will be quite minor for most systems.
    Greg
  3. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    Do a search for "Video Essentials" (VE) or "Avia"
  4. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    Build in Test Tones: These are quite good and have the advantage of not needing the external disk. But some units, Yamaha in particular, dont provide test-tones for the subwoofer port.
    Avia & Video Essential: These are great. They not only provide subwoofer tones, they also honor the LARGE/SMALL settings of your speakers and give you a rough idea of the full-signal path effect. They also describe the entire process in a simple to follow format.
    They also have some extensive video adjustment screens, and a lot of description of how to use them. It's almost a course on TV adjustments.
    Highly Recommended.
    Frequency Sweeps: This type of CD gives you several seconds of 10 hz, then 20 hz, .... all the way up. With a SPL meter you can plot how your room is affecting/enhancing some sounds. Only usefull if you plan to do some equalization to tame peaks.
  5. TimothyW
    TimothyW Extra
    Feb 6, 2002
    17
    I already have the Avia, but I want to do a subwoofer frequency sweep. Where can I get one on these CDs?
  6. Vin
    Vin Supporting Actor
    Oct 23, 2000
    546
  7. Bob McElfresh
    May 22, 1999
    5,182
    Tim: If you have a CD burner, you can download a little program called "NCHTone" (I think). This little program lets you set a frequency (in 1 hz increments) and a time, and save each tone to a .WAV file. Then you use your burner to make each one a track and you now have your own test-tone CD.
    Using this, and a SPL meter, you now have a "poor-mans" Real Time Analyzer.
