Speaker Cables with Monitor Gold Reference 60
Discussion in 'Speakers & Subwoofers' started by matthew, Jan 15, 2004.
  1. matthew
    matthew Agent
    Oct 24, 2003
    25
    I just got my Monitor Audio Gold Reference 60s and now I want to upgrade my speaker cables. These speakers for those who are not familiar are tri-wireable and I cant find any places who make a triwire cable. So maybe I biwire or just single conductor cable. If I go biwire, which terminal bridges do I remove and keep. Please, someone who knows, help!!
  2. AustinKW
    AustinKW Stunt Coordinator
    May 30, 2002
    169
    Home Depot
    12ga spool
    Single runs to GR60s
    Spend savings on software
    Enjoy
  3. Khoa Tran
    Khoa Tran Supporting Actor
    Oct 23, 2002
    569
    to be honest i've tried the home depot wire and the a lot of the bass disappeared, i thought i had something wrong but i checked and nothing...but then i put on some tara labs biwires the sound was much fuller and a more low end....that's my experience...i agree too much money on speaker cables like 1k+ is crazy but at 2-4 dollars a foot i'll spend if it makes this much difference for me...
  4. Robert Cowan
    Robert Cowan Supporting Actor
    Nov 10, 2003
    504
    i cringe at the though of home depot cable!
    audioquest will make tri-wire cable. it will of course be a special order, but they can make it in pretty much any configuration, as long as its their earth series, which has sufficient conductors for a tri-wire setup.
    if you cant find a dealer locally, i am a dealer and could help you out. their new earth series thats battery powered is mind blowing.
  5. AustinKW
    May 30, 2002
    169
    Perfectly understandable.
