speaker cable recommendation
Discussion in 'Accessories, Cables, and Remotes' started by Justin Kregear, Feb 4, 2004.
  1. Justin Kregear
    Justin Kregear Auditioning
    Feb 3, 2004
    6
    newbie needs help,
    I just purchased and onkyo TX-NR801 receiver and two infinity alpha 50 floorstanding speakers. Im moving in 2 weeks and will complete the system with 4 more alpha 50's and an alpha 37 center. I need a recommendation on some bargain speaker cables that will not compromise my system. Total system price will be about 3500+. Need to know anymore just ask.
    thanks for your help.
  2. Shane Morales
    Shane Morales Second Unit
    Jul 9, 2003
    433
  3. DaveLenhert
    DaveLenhert Stunt Coordinator
    Nov 1, 2001
    79
    Another option is Canare's StarQuad speaker wire. It comes in 3 sizes, 17 AWG, 13 AWG, & 11 AWG. The main reason that I like this wire is the easy ability to biwire and its thickness. However, it is more expensive then the Soundking wire, at last check, it was about $0.60/foot for the 11 AWE size.
    You can buy it at:
    HaveInc.
    MasterTek.
