Speaker Brackets for JBLS36
Discussion in 'Archived Threads 2001-2004' started by Stephen Houdek, Mar 26, 2002.
  1. Stephen Houdek
    Stephen Houdek Second Unit
    Jan 21, 2002
    326
    S
    I'm looking for Wall mount brackets for my JBL S36 surrounds. Does anyone know what will/won't work?
    I've exhaustively searched the JBL site for information and can only find references to actually mounting the speakers directly to the wall. I'd prefer the directional capabilities of a bracket if possible.
  2. AVspec
    AVspec Supporting Actor
    Sep 7, 1998
    515
    South Eastern PA
    Mark
    Rat Shack has one that works. It says it holds up to 8 pounds but I am using one with the 11 pound S36 with no problems.
    Rat Shack mount
    I can take a digital picture of it in use in my HT if you like. Note: The picture on R.S. site does not show the 2 hole adapter that comes with the mount that lines up with the 2 mount holes on the bottom of S36 speakers.
    Hope this helps,
  3. Stephen Houdek
    Jan 21, 2002
    326
    S
    Cool, thanks Mark. I was hoping to get a response. Actually nice they are at Radio Shack which is always close and usually in Stock.
    Digital Picture would be great.
  4. David King
    David King Stunt Coordinator
    Mar 2, 2002
    141
    In the review section at audioreview.com a guy says that omnimounts 53 RST UMK works also. Just be carefull, those suckers are heavy.
    link
    http://www.audioreview.com/pscSpeake...1_1594crx.aspx
    mentioned in the last review on the 1st page (as of this posting).
    edit, damn I wish I could spell!
  5. Hank_P
    Hank_P Second Unit
    Nov 15, 2000
    321
    19
    110
    I'm also using the omnimounts mentioned in that review. The work very well and rated to 15 lbs.
