Speaker Binding posts
Discussion in 'Archived Threads 2001-2004' started by Howard_S, Dec 29, 2001.
  1. Howard_S
    Howard_S Supporting Actor
    Nov 1, 2001
    548
    How do I know the size of my receiver's speaker binding posts? How would I go about measuring it? Anyone know the size of the 49tx's speaker binding posts?
  2. Marc Rochkind
    Marc Rochkind Second Unit
    Aug 26, 2000
    381
    If I understand your question, you want to know the diameter of the threaded part of the binding post?
    Here are two methods I can think of:
    1. Use a caliper, which is an instrument that measures small distances very accurately. What, no caliper in your junk drawer? Then read on...
    2. Carefully wrap a piece of paper one revolution tightly around the post in a slight spiral so you can draw a line and then unwrap the paper to measure the circumference of the post, which is the space between the lines on the paper. Use the formula D = C / 3.14159, where D is the desired diameter and C is the circumference you measured.
