George Caronan
- Nov 25, 2003
Hello everyone. Hopefully by the middle of the year or maybe even earlier, I plan on upgrading my speakers and subs. Here is my gear and considerations:
1. Surround Sound Processor: AVM 20 V2.11
2. Amp: Parasound HCA-1500 X 2 [200 WPC] - bi-amp mains
3. Amp2: Parasound HCA-1206 [135 WPC] 2 centers, 4 surrounds [side and rear]
4. TV is a Mitsubishi 55" HDTV Widescreen [rear projection]
5. Wires are 14 WPG for mains/centers + 16 WPG for surrounds
6. Interconnects are all Monsters
7. From the main listening position, the specs are:
Mains: 9 ft [1 foot away from the wall]
Center: 9 ft
Subs: 8 ft [both are on the sides of the TV]
Side Surrounds: 6 ft
Rear Surrounds: 6 ft [4 ft apart]
Two story house with high ceilings
8. Listening is 50/50 on HT and music
Budget will be around $4,500.00. Subs are in the budget although I am currently using two Infinity 150-watters. I prefer floorstanders for the mains. What would you knowledgeable souls recommend? Bookshelves would be fine as long as they are bi-wireable/bi-ampable though I have a feeling there will be compromises when listening to music. I usually listen to Classic Rock with an occasional Sinatra or Classical for the fiance! My apologies if the post is a bit long but I am looking forward to all your opinions and expertise. Thanks to Ernest Yee for kick-starting this.
-George
Center: 9 ft
-George
