so i bought one of the many android streaming media boxes with Kodi installed on it off of Amazon.
i plugged the HDMI output of it directly into the back of my TV while and audio/video has been fine. Once i got everything working (apps, addons, etc..) I decided to integrate it into my home theater in the basement.
i have an older sony receiver (~2008) that accepts two types of digital inputs - orange RCA and optical connectors (see image below) and one analog type input (red-white RCA connectors).
so my Kodi box also has a SPDIF output (3.5mm) and I tried to connect that using an optical cable to the optical port on my receiver below without success (used a used a male Toslink to male Toslink cable + 3.5mm adapter). i adjusted settings on the Kodi box to output via SPDIF but could not get it to work. Support for the Kodi box was non-existent and I learned through some sleuthing that many of these crappy android boxes from china have problems with the SPDIF outputs. I don't know if that is the case, but i decided to go another route because that optical port in the back of my receiver was used for my PS3 anyway.
I bought an HDMI A/V signal splitter because I knew the audio signal was good there (see splitter below). The splitter takes an HDMI input signal and splits the audio from it and provides a SPDIF output and an HDMI output. So the HDMI output from the Kodi box goes into the splitter and the HDMI output from the splitter goes on to my projector. Now this is where I am having trouble. Initially, I took the the SPDIF output of the splitter and used a 3.5mm connector x RCA male cable to output the signal to the orange RCA input on the receiver (one of the two digital inputs). The audio didn't work. My Sony receiver did not output anything..? However, I removed the cable from the SPDIF output on the splitter and plugged a pair of earphones into the output. I got sound coming in. After figuring out that an analog signal was coming through (headphones gotta be receiving an analog signal right?), I used a male 3.5mm plug x (2) RCA male plug adapter cable from the splitter audio output to the analog inputs on the back of my Sony receiver. It works, but the sound quality is of course not that great.
Any thoughts on this? I am kind of at a loss about how SPDIF works. I thought it was a digital signal - but how do my earphones work on this?
i am going to try to connect my toslink - toslink +3mm adapter cable from the splitter to the optical input on my receiver next to see if that works.
http://www.amazon.com/PORTTA-PET030...&redirect=true&ref_=oh_aui_detailpage_o02_s00
