Richard_s
- Nov 25, 2000
I just got a new DVD player. It is the Philips DVD724AT progressive Scan and can play all of the encodings I am learning how to use (VCD, SVCD, CVD etc). Now this unit has settings I have no idea how to set.
My receiver is the Yamaha HTR-5550
There are two settings for the SPDIF in the DVD player:
SPDIF OUT: RAW or PCM I have no idea which setting is best/correct how do I determine this?
LPCM 96K: OFF(never used) ON (chosen Automatically)
Now the DVD manual states that the higher the sampling rate the better the sound and some sourses are at the 96K level so it seems I would want this ON. The problem is that the manual for my Receiver states that the unit can handle the 96Khz sampling Digital signals with the following restrictions:
1) DSP Programs cannot be used
2) Sound will be output as 2 channel stereo from only the left and right main channels (subwoofer also if set to small). Therefore the level of effects can not be adjusted while listening to such a source.
What kind of sources have the sampling rate at the 96khz level? Why would I want to restrict any source to be forced to stereo when I have DD5.1 and DPLII? Can't figure out what setting should be used but there must be some advantage to using the 96khz setting or it would not exist but why use it?
Thanks ALL
Thanks ALL
