SPDIF quesiton
Discussion in 'Playback Devices' started by Anthony Moore, Jul 20, 2005.
  1. Anthony Moore
    Anthony Moore Supporting Actor
    Jul 12, 2001
    707
    Ok, my computer has a sound card with an SPDIF output on it. I bought a cable that says SPDIF on it. But where will this go into my receiver? I have a Denon 3802. Will this go into the DIGITAL IN (coax)?
    Or do I need something else?
  2. jim.vaccaro
    jim.vaccaro Second Unit
    Jun 27, 2005
    425
    S/PDIF is an optical connection. You'll have to run optical digital cable from your sound card to the optical digital input on your receiver (not the one that says "coax")
    Is the output on your soundcard a mini-S/PDIF, or is it full size? The mini port will look like a headphone jack. If you have the mini port, you'll have to use an adapter on a standard optical cable to plug into your sound card.
  3. Anthony Moore
    Jul 12, 2001
    707
    hmmm..
    I know my optical cables I have running from my CD and DVD player look nothing like the spdif cable I have. They have a different connection on the ends (you can see the red light).
    EDIT: OK this is what I have, the rear inputs..here's a picture:
    http://www.crutchfield.com/S-FoD9OaJ...&display=L#Tab
    Right now I have it in the yellow input next to the other optical inputs on the bottom left. I think it says COAXIAL. If this isnt right, where on here should I put it?
    Thank you.
  4. Anthony Moore
    Jul 12, 2001
    707
  5. Michael Reuben
    Michael Reuben Studio Mogul
    Feb 12, 1998
    21,763
    2
    That's the right one. As you've discovered, S/PDIF (or, more commonly, "digital") connections come in two varieties, coaxial and optical.
    M.
  6. jim.vaccaro
    Jun 27, 2005
    425
    Doh, you're right. I was thinking S/PDIF was another name for Toslink, which is the optical digital interface.
