SPDIF Connection? What is that?
Discussion in 'Archived Threads 2001-2004' started by RodNoble, Nov 6, 2002.
  1. RodNoble
    RodNoble Agent
    Oct 11, 2002
    31
    Its me the new guy again.. so anyway.. as some of you might have seen i needed to get a new Digital cable box with s video.. anyway, I have it and its working great, but my question now is, this new box has a SPDIF connection which i heard was an audio connection.. but there is only one plug, so i cant see how that works for audio, unless its a mono audio channel.. what exactly is it..
    My next question.. the box says its dolby digital, but there is only a 2 channel audio.. I was under the impression that dolby was suround? or is it just the quality of dolby?
  2. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    SPDIF is a coaxial-digital connection. If your CATV box really DOES provide this, run it to a coaxial-digital input on your receiver.
    SPDIF stands for Sony Phillips Digital Interface Format - This was created for DVD players in 95.
  3. DaveB
    DaveB Stunt Coordinator
    Aug 20, 2002
    196
    If the box supports dolby digital, you'll need to use the SPDIF digital-coax to get surround sound. The reason why there's only one cable is because all 6 discrete channels are decoded from one continuous bitstream. Obviously you've got to have an appropriate surround set-up as well.
    Cheers!
  4. Bob McElfresh
    May 22, 1999
    5,182
    Note: that connection can give you all the flavors of sound from 1.0 up to 6.1. Some stations will be in mono, some cable stations will be in pro-logic, some HBO/SHOWTIME stations will be full 5.1.
    ONE BIG PROBLEM: These ports tend to only provide sound for channels that are part of the "Digital" service. In many cable systems, the lower channel numbers are still analog and this connection will go silent. This makes channel-surfing a real pain. You have to have the TV speakers on for the channels below 100, then the receiver will kick in for channels above. If you hook it up, watch for this.
  5. Craig Robertson
    Craig Robertson Supporting Actor
    May 12, 1999
    982
  6. Scott Merryfield
    Dec 16, 1998
    12,808
    1,365
    9,110
  7. StephenL
    StephenL Second Unit
    Nov 21, 2000
    341
  8. RodNoble
    RodNoble Agent
    Oct 11, 2002
    31
    sounds good, thanks guys. going to give it a shot when i get home..
    One last question.. can i use a normal audio rca cable to connect it?
  9. PaulT
    PaulT Supporting Actor
    Oct 28, 2002
    932
    Rod,
    Standard audio RCA cables are 50 ohms. Digital S/PDIF RCA cables are 75 ohms. You should go out and get the proper impedance cable. Try Monster or even RatShack.
  10. John Kotches
    John Kotches Cinematographer
    Mar 14, 2000
    2,635
    Correctly made, a composite video cable impedance is also 75 ohms.
  11. Bob McElfresh
    May 22, 1999
    5,182
