Sp4800 Vesa Port
Discussion in 'Home Theater Projects' started by DianaAllard, Jan 29, 2004.
  1. DianaAllard
    DianaAllard Extra
    Dec 23, 2003
    20
    I am using a VGA to component cable (40ft)02835 HDTV 5-RCA/BNC TRIPLE SHEILDED RGB BREAKOUT CABLE and trying to hook to my ONKYO CP701 DVD player to the projector but I get no signal. In the manual, it says "FOR HD and Progressive sources use the Component to VESA adapter along with a Component cable (not included). Should I have purchased a long component cable instead? My next question is if I will be able to hook up the HD cable box when it comes with this cable. I am assuming not. I might need a video switch in order to use both? I have read that the projector has a good switch in it and maybe I should just use the projector for the interlacing?
    Any help would be great. Thanks in advance.
  2. DianaAllard
    DianaAllard Extra
    Dec 23, 2003
    20
    Is this what I need to hook to the VESA adapter already supplied.
    COMPONENT VIDEO DIGITAL TV TRIPLE RCA SHEILDED 25FT
