Source for white, wall mount speaker grills?
Discussion in 'Home Theater Projects' started by Patrick.C, Aug 25, 2004.
  1. Patrick.C
    Patrick.C Second Unit
    Jul 6, 2004
    447
    Here's my situation: I'm flush mounting my rear projection in a wall. My builder is framing out a "box" above the set to serve as a cubby hole of sorts for my center channel speaker. I would rather not have the speaker (and its cubby hole) showing, though. What are my options for something to cover up the hole? Are grills available? Or should I just pick up some white grill cloth from Parts Express and make my own?
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,130
    40
    6,610
    Katy, TX
    Wayne
    Patrick,
    If you’re custom building a cubbyhole for your speaker, it only stands to reason that you will have to custom-build a grill as well. It really isn’t hard. You can find suitable cloth at a fabric store. Some kind of knit that stretches will probably work best, and with a low thread count: The more light you can see through it, the better it will pass the high frequencies.
    Wayne A. Pflughaupt
