Soundproofing supplies near Hamilton Ontario?
Discussion in 'Home Theater Projects' started by Ray Stericker, Jan 2, 2004.
  1. Ray Stericker
    May 29, 2002
    26
    I am building a home theatre and want to reduce the amount of sound that travels through a wood 2x4 stud wall to the next room. I am looking for a source of supplies near Hamilton Ontario Canada. The wall is about 13 ft wide, by 8 ft high.
    I know Home Depot has the "safe and sound" rock wool to put in the bays. I used that before for the bedrooms upstairs, and will use it again for the theatre.
    Home Depot also has "resilient channel" that is used to mount a second layer of drywall so it doesn't transfer as much sound to the structure. I am trying to avoid this, because it will increase the thickness of the wall significantly. I am also a little unsure about how you trim out a wall like this (baseboard, outlets, ceiling joint tape etc.) without destroying the resilience you create.
    I was considering Mass Loaded Vinyl (MLV) but can't find a local source. I don't want to pay to ship that stuff if I can avoid it. Does anyone know of a source in my area? It sounds simple to install.
    Any other suggestions for soundproofing that are cheap and simple?
    Thanks for the help,
    Ray
  2. Derek_P
    Derek_P Stunt Coordinator
    Dec 30, 2003
    74
