Sound & Vision Home Theater Tune up DVD (1 Viewer)
DennisP
Anyone have an opinion on this DVD? It's produced by Ovation Software (same people that make the AVIA). Does anyone know if the S&V DVD will allow you to calibrate your TV as well as the AVIA DVD? The S&V DVD comes with a blue filter and test patterns to adjust all the TV's user accessible picture controls (Sharpness, Color, tint, Contrast). There are also a ton of other test patterns included on the DVD.
Thanks to those who answer.
Phil Iturralde
Yes, from what I viewed, ... it does as well as AVIA! But, so far, I have not really used it for any real Video or Video Calibration work. I actually bought S&V HT Tune-up for the DTS & 6.1** test signals (**future AV Receiver upgrade - next year?). I did check the DTS REF Calibration Test Signal @ 85 dB, and my Yamaha RX-V995 Volume Control REF Calibration Mark was identical, to my Video Essentials REF Calibration Test Signal @ 75 dB.
I personally use my ole' Video Essentials DVD for all my Video & Audio (has dedicated LFE test signal) REFERENCE Calibration because I can do that quickly (used it since 1999).
Later, I bought AVIA, and I checked my VE Video Calibration settings (no changes req'd) but thought the 16:9 Overscan Test Screen to more accurate vs. VE.
If you're planning to use one Video & Audio Calibration DVD, S&V HT Tune-up DVD should fill all your Calibration needs.
Phil
ChewyWaffles
