ChrisDumont
- Jul 8, 2003
I plan on getting:
2 Connoisseur C-9 Energy
2 C-3 bookshelf ''
1 C-C3 centre speaker ''
2 CR3 surround speakers ''
PB1-ISD SVS subwoofer
Denon 3803 receiver
Now what kind of speaker cables should I get? (12 gauge or something?) Oh and this may sound dumb, but if I purchased these speakers, do they come with any cable? Also, whats the proper way to setup up a 7.1 system? I heard you have the 2 surrounds pointing right at your ears a certain level above your head or something like that (and how would I setup every speaker?), and if I wanted to, could I use bookshelf speakers for the surrounds? (in case I wanted to downgrade to 5.1). Is 7.1 that much better than 5.1? If not I may just go for 5.1 since it would be cheaper. And is that subwoofer good for a 8' ceiling, 7' width, 10' length room? I may move into a bigger room in the future (in a few years) so I would like something with punch just in case my future room is larger than my current one. One more thing, what would I use to calibrate my sound system? And does calibrating make that much difference? Thx
2 C-3 bookshelf ''
Denon 3803 receiver
