Sound Quality Without MP3 Decoding?
Discussion in 'AV Receivers' started by Burki, Sep 25, 2003.
  1. Burki
    Burki Agent
    Aug 31, 2003
    45
    Let's say i want to hook up my pc from digital out to a receiver but receiver doesn't have mp3 decoding or it doesn't say this in it's features , will be sound qualiy worse? I mean if there is no mp3 decoding will it be big difference with the sound?
    Thx from now...
  2. Aaron Gilbert
    Aaron Gilbert Second Unit
    Sep 17, 2003
    319
    When you say digital out from your PC, are you talking just a S/PDIF in coaxial or optical on the back of your sound card?
    If so, you don't have to worry about MP3 decoding in your receiver. Any sound card outputting digitally through this standard type of interface will be using standard PCM, which to your receiver is no different than the optical output from anything else. Some sound cards even will pass a DD/DTS six channel signal through their digital output. Mine claims to, but I haven't tried it yet.
    So, when you want to play MP3's, you start up Windows Media Player or Musicmatch or whatever MP3 software you happen to use, get your tracks playing, and the digital output coming out your sound card will be converted by your receiver.
    All that said, I have seen receivers advertising MP3 decoding, and some even with a USB input that says you can stream MP3 files through that connection and let the receiver decode them. Frankly, I don't understand this. For one, I don't know how you get non-decoded MP3 data to stream out of any port on my computer. And secondly, why should we assume your receiver can do a better job decoding MP3's than your computer?
    With sound cards having digital output going for under $30 these days, spending any amount extra on a receiver which will decode MP3s doesn't make sense to me. One could even argue that the sound quality of MP3's is poor enough that you might as well just use an analog connection anyhow... [​IMG]
    Hope that didn't add too much confusion.
    Aaron Gilbert
  3. Burki
    Burki Agent
    Aug 31, 2003
    45
    No confusion buddy , i was thinking the same thing with you but wanted to get some other ppl's ideas. I have a Creative Sound Blaster 4.1 w digital out which i dont know good or bad but i think if i use its digital output at the back side , i can get much better sound.
    Thx for your reply...
