Scott L
- Feb 29, 2000
The basement theater connects to the upstairs via a run-of-the-mill hollow door in the kitchen. As you can imagine it gets very noisy up there when the theater gets loud. I went to Lowes yesterday and saw a "Safe 'N' Sound" Door from Premdoor which is solid core, but still made out of wood. Cost wasn't overbearing- about $74 with no pre-hung holes drilled ($100 Pre-hung) but I was wondering if it would be better to buy that sound foam that recording studios/TV studios use instead.
Link Removed place sells 4' x 8' sheets for $28 which isn't that cheap. Any place to get them cheaper? And what are other alternatives to soundproofing a door, or just a whole new door period? Thanks..
Scott
Scott
