Sound problem with Pioneer VSX-912
Discussion in 'AV Receivers' started by Donald_S, Aug 9, 2005.
  1. Donald_S
    Donald_S Stunt Coordinator
    Oct 19, 2003
    103
    Yesterday I watched a movie with no sound problems. Today I turn my system on and I'm getting a nasty staccoto sound coming from my center channel and rear surrounds through my Fluance speakers. If I switch to stereo, the problem goes away. I've tried different DVDs with the same result. I suspect my Pioneer receiver has gone bad, but I'm not sure how to diagnose the problem. Ideas would be appreciated.
    Donald
  2. lee ison
    lee ison Stunt Coordinator
    Oct 31, 2004
    61
    sounds like a speaker wire might be lose on the back of the rec. i suggest checking all the connections , it may as small as a single strand touching another wire or terminal, then check all connections on each speaker... hope this helps.
