Sound Level Meter for Newbies
Discussion in 'Archived Threads 2001-2004' started by DennisM, Mar 18, 2002.
  1. DennisM
    DennisM Auditioning
    Mar 3, 2002
    4
    I've found that a reciever with the test tone feature for setting the equal sound level of all channels in a 5.1 or 6.1 sound field enviorment are not very reliable. Most of the time I have found the the rear channel volumes are too low even after the test tone. I have found a more accurate volume setup for your theater sound is to use a sound level meter in conjuction with the recievers test tone. You will notice the difference when you listen to your first Surround Sound or Dolby Digital DVD.
    Enjoy!
    Dennis
  2. Chuck_C
    Chuck_C Stunt Coordinator
    Oct 31, 2001
    67
    You will find it even more accurate using a Video Essentials or Avia setup DVD instead of the receiver's test tones.
  3. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    Dennis,
    Your post above says you find the receiver tones inaccurate, so you use the ones in the receiver instead?
    What?
    -Vince
  4. ColinM
    ColinM Cinematographer
    Dec 9, 2001
    2,050
    Vince -
    You slay me
    [​IMG]
    Just going for 600....
  5. Dave Schofield
    Dave Schofield Second Unit
    Sep 30, 1999
    401
    I think he means that using your ear to balance speaker volumes isn't as good as using a SPL. Its informaiton that could have been gleaned from thousands of other posts here, but nonetheless, I think that is what he meant.
