Sound Level Meter Calibration question.
Discussion in 'Home Theater Projects' started by Chris VW, Jan 26, 2005.
  1. Chris VW
    Chris VW Stunt Coordinator
    Apr 16, 2003
    68
    Hi,
    I purchased a digital meter from Radio Shack. I understand what settings to put it on and it works fine with the test tones put out from my Denon 3805. At what volume should I have the 3805 and what do I do with the numbers I get? I set the meter at 80 so do I adjust all of the speakers to 75 or 80 dbs or what? I'm unclear on that part. Any advice or tips would be appreciated.
    Thanks in advance!!
    Chris
  2. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
  3. Chris VW
    Apr 16, 2003
    68
    John,
    Thanks for the quick reply. I looked at that info and it answered all of my questions. When the 3805 was set up it was calibrated with the autocal mic. The fronts are all registering 73dbs, the subwoofer is 74, and the rears are 71 nand 72 dbs. is this Ok or will bringing them all to 75 make an improvement?
    Chris
  4. Jeff Gatie
    Jeff Gatie Lead Actor
    Aug 19, 2002
    6,531
    15
    I have a Denon 3801 and mine defaults to "00" volume level when you enter the calibration mode. This means your reference level master volume is automatically set to "00" if you calibrate to the proper tone volume. I doubt it has changed on the 3805. Denon test tones are 30dB below reference, so you calibrate to 75dB for a reference level at "00" mster volume.
