Sound Level Differences
Discussion in 'Archived Threads 2001-2004' started by Kelvin F, Nov 23, 2001.
  1. Kelvin F
    Kelvin F Auditioning
    Nov 12, 2001
    14
    Hey Guys,
    I watch mostly action and sci-fi movies on my home theater system.I`ve noticed in a lot of cases a big difference in sound levels between diffent movies. For example,if i put in x-men i have to turn the volume up to 3 ,if i put in gladiator with the volume on 3 my windows would shatter. Is this normal? If so why isn`t there a industry standard for audio levels in action and sci-fi movies? This may sound like a stupid question, but i just had this running through my mind. Any input would be greatly appreciated, THANKS!!
  2. YANG
    YANG Second Unit
    Feb 10, 1999
    471
    2
    "For example,if i put in x-men i have to turn the volume up to 3 ,if i put in gladiator with the volume on 3 my windows would shatter. Is this normal?"
    Welcome to the forum.KELVIN.
    X-MEN is a DOLBY DIGITAL 5.1 only release,GLADIATOR comes with a DTS 5.1 track.When you compare the two,you should see if you are comparing the same format tracks...both DD5.1 of the two movies.
    Regular DTS DVD releases,are several level higher in volume than regular DD5.1 track.
  3. Michael Reuben
    Michael Reuben Studio Mogul
    Feb 12, 1998
    21,763
    3
    There are numerous technical reasons why one disc might sound louder than another at the same volume setting. But even if you eliminated all technical factors, some films will still play louder because that's how the filmmakers chose to present them. Some films are darker than others; some are louder than others. Why should there be any "standard"?
    (N.B. I'm not talking about the calibration of playback equipment to "reference level", which is a different story.)
    M.
  4. Dan Hitchman
    Dan Hitchman Cinematographer
    Jun 11, 1999
    2,713
    Actually, you could also say the Dolby Digital versions many times are softer than the DTS version. DTS encoding does not used dialog normalization or peak limiting.
    Dan
  5. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    Yep, and if Dialog Norm was use properly by the person encoding the disc, Kelvin's problem would bever happen...
    -Vince
  6. Kelvin F
    Nov 12, 2001
    14
    Thanks Guys you all have been very helpful. I didn`t realize that DD tracks used compression. I guess one learns something new every day.
  7. Michael Reuben
    Feb 12, 1998
    21,763
    3
  8. Kelvin F
    Nov 12, 2001
    14
    Thanks for your input Mr.Reuben. The dialog sounds pretty close between these two movies but the action sequences in x-men seemed to lack presence "in your face" compared to gladiator which rocked me off my seat.
  9. Michael Reuben
    Feb 12, 1998
    21,763
    3
    Dialnorm doesn't affect the level of dialogue; it affects the overall level of the soundtrack relative to dialogue.
