follicle
- Jan 9, 2011
- Jon
I just got my 42' LG LCD setup with a Philips Blu-ray home theater system (HTS3251B/F7), and I'm having an issue with sound delay. From what I hear, it can be a common occurrence. The sound is playing about half a second before the video and is causing some extremely noticeable lip sync issues in areas. I've seen this on numerous movies.
First, I'll say that I've already ruled out the television itself, as I've played the sound through just the television speakers while playing a Blu-ray and there were no delay issues whatsoever; however, when I use the surround sound speakers, it's clearly evident. My old DVD home theater system was also a Philips and it had a "speaker delay" setting where you could set the delay of each speaker in milliseconds, but I never had to use it.
After paging through the manual of my new Philips system, it appears that this system's audio delay settings are controlled by a setting called "speaker distance." Instead of adjusting the delay of each speaker in milliseconds, I have to set the distance of each speaker to the listening position in feet or meters (which is difficult, taking into consideration that I have several listening points within my living room). This setting is described in the manual as: "Sets the distance from the listening point to each speaker to get the ideal delay time." Right now, my main concern is the front center speaker, as this is where most of the dialog comes from. I've changed the distance setting to 9 ft. (average distance to all listening points) with no effect. Out of curiosity, I tried almost every other distance setting (from 0 ft. to 15 ft.) with no results.
It seems odd to me that the audio delay would be set by a "speaker distance" setting. Does distance really even have an effect? Based on the results I'm getting, it doesn't seem like it. It seems like it would make much more sense to be able to actually set the delay time of each speaker instead of the distance.
Any thoughts on this? Suggestions?
Thanks in advance for any replies!
