Sony's New AVD-C700ES /S500ES
Discussion in 'AV Receivers' started by Marv, Mar 26, 2004.
  1. Marv
    Marv Stunt Coordinator
    Feb 21, 2000
    110
    I'm considering one of these two units but from what I can tell neither of these units has any type of Bass/Treble adjustment. I downloaded the manual and it is not even mentioned. An ES product and no basic sound contour controls? I'm also a little disappointed by the Bass Management, Small/Large that's it. I've owned 1 Sony ES a STR DA777 and that sucker had more flexibility than you could almost use. So whats up with these? I think I just talked myself out of them.
    -Marv
  2. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    Likely the controls are the same as my last 2 Marantz receivers were - controls are digitial and adjusted in a setup menu somewhere. I have setup a DA3ES, and I know the controls are only available in the menu system.
    The AVDs are not combo units, so I'm sure they had to make some compromises to package everything.
    Then again, I also never adjust my tone controls so...
