Sony widescreen mode too wide?
Discussion in 'Archived Threads 2001-2004' started by Thi Them, Dec 14, 2002.
  1. Thi Them
    Thi Them Producer
    Apr 20, 1999
    3,649
    I just got a Sony Wega 27" flat screen. In widescreen mode when viewing a DVD, the height of the picture is a bit shorter than in regular mode. Does anyone else have this problem?
    ~T
  2. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    An overscan adjustment (hor. size, vert. size) may fix this.
    Unfortunately for some TV sets there is only one overscan setting that affects all aspect ratio modes. If so, you will always have the disparity when quickly switching back and forth between 4:3 and 16:9. Fortunately, unless you are fidgeting and tweaking and doing A/B comparisons, you probably won't notice anything wrong with the picture using a single compromise setting.
    If you have 16:9 mode on the TV, leave the DVD player in 16:9 mode. There is no further need to view a 16:9 enhanced (anamorphic) movie in regular (4:3 mode) on your TV.
    Video hints:
  3. Jack Briggs
    Jun 3, 1999
    16,738
    129
    It's worth noting that many have observed an "oversqueezing" phenomenon on some WEGAs.
  4. Thi Them
    Thi Them Producer
    Apr 20, 1999
    3,649
    I guess I'll search for past threads regarding this oversqueezing problem. Thanks.
    ~T
