Sony Wega TV problem
Discussion in 'Archived Threads 2001-2004' started by BrendanG, Feb 13, 2003.
  1. BrendanG
    BrendanG Agent
    Feb 13, 2003
    27
    I just recently bought a sony wega kv-27fs100, a 27 inch. I dont see to have any of the picture problems discussed in this forum but i did just accidentely break the front video input on the tv. I was pulling out the front composite video just as i normally would when the screen went blank. Now the jack only work when i shake the video connector. I already have sony lined up to come and fix the problem in 2 weeks, but my question is do you think i should just return the tv because it might be a lemon? or just keep it and hope nothing else goes wrong. Im not sure if anyone else has had this problem with there sony tv and whether or not it will lead to further problems with the set. Any suggestions would be helpful. Thanks
  2. Scott Kimball
    Scott Kimball Screenwriter
    May 8, 2000
    1,500
    If the other inputs are okay, and you have no other problems, it's most likely an isolated event. If it were mine, I'd get it repaired.
    -Scott
