Sony WEGA question
Discussion in 'Archived Threads 2001-2004' started by Victor_W, Jul 9, 2002.
  1. Victor_W
    Victor_W Agent
    Jul 8, 2002
    29
    Hi all,
    I was wondering if you guys could give your opinions of these 3 Sony WEGAs should I get? They are the 27FS13, 27FV300 or the 24FV300. I definitely want the 16:9 enhanced mode, so I don't know if the 24 incher has that mode or not. Also, I know that the FV300 has a 3D digital combination filter instead of the 3-Line digital combination filter that the FS13 has. Is this a BIG difference?
    Thanks for your help.
    vic
  2. AllanN
    AllanN Supporting Actor
    Mar 15, 2002
    950
    Im not sure about the comb filter. Check out www.sel.sony.com. But only the 27" and up WEGAS have the V-Compression
  3. Paul_Dunlop
    Paul_Dunlop Second Unit
    Nov 28, 2001
    318
    Hi
    I have the 27FS13 and love it.
    If you use an S-Video or component connnection, the comb filter is bypassed anyway, so bear that in mind.
    I have the Cable TV, Xbox and VCR hooked through S Video and the DVD through component, so i don't think i've used the filter yet.
    The FV usually adds PIP and better speakers. Neither of these were a concern to me, so the FS was a better buy for me. Also it adds 'Auto' 16:9 enhancement - this is a nice feature, but moving through the menu to manually turn it on for DVD's is not a big deal (i use my RCA remote macro commands anyway)
    Hope this helps
  4. Fernand
    Fernand Agent
    Jul 3, 2002
    38
    I'm with Paul in this matter.
    I have a WEGA 27FS13 and it kicks butt. If you have a HT system you don't need the FV cause you're gonna waste money in better TV speakers when you're not gonna use them. About the PIP... waste of money too. Use the last channel or recall button in your remote !!
    BTW the 16:9 enhancement is cool! [​IMG]
  5. Steve Lockwood
    Steve Lockwood Stunt Coordinator
    Dec 3, 1999
    122
    Paul
  6. Brice
    Brice Stunt Coordinator
    May 21, 2002
    104
    Does anyone know if the 24fv300 (or even 20fv300) have the 16X9 squeeze?
  7. JasonWW
    JasonWW Agent
    Jul 18, 2002
    34
    I think it's only the 27" and up that have the squeeze. Also, it's the 13's that have a single tuner, the 17's have the dual tuner and the FV have the dual tuner, better speakers and a few other little things.
  8. Justin Lane
    Justin Lane Cinematographer
    Jan 18, 2000
    2,149
    110
