SONY Wega experts--Hook-up
Discussion in 'Archived Threads 2001-2004' started by Steve WC, Feb 3, 2002.
  1. Steve WC
    Steve WC Stunt Coordinator
    Dec 15, 2001
    180
    Model 32fv27.
    I am supposed to be able to use my TV tuner for unscambled channels and my cable box for scrambeled using the TV's "converter".
    Cable line in to vhf/uhf.
    Converter to Cable box in.
    Cable box out to TV AUX.
    My TV tuner works with all the unscambled but scrambled reads "no signal". (TV set to Channel 3, Cable box to station, Press Ant to switch.)
    Did I miss something?
    Steve
  2. Orlando
    Orlando Stunt Coordinator
    Aug 1, 2000
    208
    I don't remember what the setting was, I have to look later. But remember that you have to set the TV to one of the Aux inputs not the TV on channel 3. Hope it helps if not I will check tomorrow after my Super Bowl party.
  3. Steve WC
    Dec 15, 2001
    180
    Problem Solved. Thanks for ALL your help.
