Sony VPLHS1 how to flip image for ceiling mount
Discussion in 'Archived Threads 2001-2004' started by Bill Cheng, Jun 16, 2002.
  1. Bill Cheng
    Bill Cheng Auditioning
    Apr 25, 2002
    11
    Can anybody tell me how to flip the image of the VPLHS1 so that it can be mount on the ceiling.
    Thanks in advance
    Bill
  2. Christian C
    Christian C Extra
    Nov 2, 2001
    16
    1. Go to Factory Mode -On the Remote or keypad press (enter) (enter) (left) (enter), then (up) when it asks “do you want to enter the factory mode?"
    2. Then enter the menu you will see that your limited menu now has far more sub menus.
    3. Go to "DEVICE ADJUST" then "P/DRIVE" setting and press enter
    4. Stroll with up or down arrow untill no.40 "OTHER/INSTALATION" setting appears
    5. You will see number "0"(Which represent Floor-Front) next to it. Using Left or Right arrow on remote you can change to "1" (Ceiling-Front) "2" (Floor- Rear) "3"(Ceiling-Rear)
    I think that “2” and “3” values are if you are planning to project through the back of the transparent screen.
    6. There are various other adjustments within the factory menu and you may be tempted to change them. Ignore them all unless you know what you are changing, since if you change these to the wrong values you may never see a proper picture again!!!
    7.Exit the factory mode same way you entered.
  3. Bill Cheng
    Apr 25, 2002
    11
    Got u
    Thank you
    Bill[​IMG] [​IMG]
