Sony VPL VW10-HT
Discussion in 'Displays' started by Stephane, Jul 13, 2003.
  1. Stephane
    Stephane Stunt Coordinator
    Mar 21, 2002
    138
    Ok I did a search, but nothing turned up, so I will ask this.
    I have just changed the bulb for my projector at home. I know that there are 2 buttons you have to press on the phisical unit to get it to rest to ( Zero ) hours for the bulb. For the life of me I do not remember which 2 buttons to press ...
    Can anyone out there help me so I can fire up my FP..
    Stephane
  2. Gregg Loewen
    Gregg Loewen Video Standards Instructor, THX Ltd.
    Insider
    Nov 9, 1999
    6,373
    32
    New England
    Gregg Loewen
    you have to enter the service mode, then hit the reset...there might be another way??
  3. EricN
    EricN Stunt Coordinator
    May 30, 2000
    71
    Stephane, read your VW10HT manual. The 4 arrows on the control panel have to pushed in a certain order. I just had bulb 3 installed and the installer pointed out the sequence in the manual for me. I am not at home or I would post it for you. The sequence gets pushed then you turn the projector on. No service menu is required.
  4. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    I have the 11HT and I am also not at home. I will chime in later. Do let us know if you immediately noticed an improvement in PQ once you changed the bulb. Just curious.
