sony vph 1252 qm
Discussion in 'Displays' started by david_rew, Jan 29, 2005.
  1. david_rew
    david_rew Auditioning
    Jan 27, 2005
    3
    Can anyone help me to clarify if it is possible to (cheaply) connect my sony vph1252qm projector using RGBvh to my Onkyo 602 amp which only has component/svid/composite connections?
    I have a hd stb which i would like to connect through the onkyo but want the best possible quality..
    not sure if svid is lesser quality than RBG comp.. how can i get hd to my projector via my amp??
    please help
    I tried connecting the pj directly to the rgb output of the set top box dgtec dh-2000a rgb out but does not work! the rgb cables are red green blue and yellow (4) and the stb conns are rgbhv.
    I am a beginner so be nice to me!!
    confused of Perth.....
  2. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    RGBhv is a different signal type than component video. You need to use a transcoder to change component video (YPbPr) into RGB.
    I forget what exactly the scan limits are for the 1252, but if you need more info on what you can feed it, see the AVS CRT forum.
