Sony V444ES Speaker/Sub Settings...HELP!
Discussion in 'Archived Threads 2001-2004' started by Zach, Aug 7, 2002.
  1. Zach
    Zach Agent
    Feb 10, 1999
    32
    I just added a hand-me-down Sony V444ES receiver [​IMG] to my get up. I have a set of Energy eXL speakers (front, center, surrounds and matching 100W sub). The V444ES has so many speaker/sub settings/tweaks that I'm a little intimidated.
    Does anyone have suggestions for small v. large, Mhz cuttoff levels (etc.) suggestions?
    Thanks for any suggestions! [​IMG]
  2. Phil A
    Phil A Producer
    Oct 1, 2000
    3,181
    44
    1,610
    Central FL
    Phil
    Are those the bookshelves that specs indicated go down to 60 HZ? If that is the case, try 'small' and set the crossover at 60 for starters and then you can experiment. If you want to use the bass redirection, you need to define speakers as 'small.'
