Sony v444es & d444es
Discussion in 'AV Receivers' started by Stan Rich, Sep 2, 2003.
  1. Stan Rich
    Stan Rich Stunt Coordinator
    Nov 24, 2001
    177
    What are the differences??Just bought the V at eBay $400.00
    and wondering if I did the right thing?
  2. JackS
    JackS Supporting Actor
    Jan 17, 2002
    634
    Some of the European owners could answer you question better than I, but the only concern I can think of would be voltage requirements. Since you purchased this in the US, the 4ES you bought may be equiped with a dual voltage converter. The bigger problem could come with the tuner if the V4es has one. I'd contact the seller with these questions or any others you may have. Good luck, Jack Edit- Excuse me 444es but the same principals apply.
