Sony UBP-X800 freezes and locks up on Chapter 6 of Dune4K (1 Viewer)
3dbinCanada
Ted
I had to switch to the BluRay copy of the disc to finishing watching it. It stuttered on a couple of 4K releases in the past but a little rewind and play and it played through. Dune totally locks it up. Anyone else with this issue?
Lord Dalek
Joel Henderson
Try unplugging the X800 for an hour. That's the usual fix. If that doesn't work check the disc, it might be defective.
It has been noted that three-layer UHD discs (like Dune) are problematic for many UHD players. Make sure you've wiped the disc thoroughly. Even though you may not see any marks or prints, there is a manufacturing residue that can interfere with the very finicky lasers in UHD players. Wiping them with a microfiber cloth often solves this problem.
Jim*Tod
Richmond, VA
Jim
I have had the Sony UBPX700 for a little over two years. About a month ago when I turned on the Dolby Vision function the player ceased working. It worked fine when it was off. All the software updates had been installed. I went so far as to buy two different new 4K players, one Panasonic and another Sony, both of which turned out to be defective. I went back to my UBPX700 and gave one more thing a try---I used the function to take everything back to factory settings. Suddenly the Dolby Vision function worked and there have been no problems since. Not sure if this would help with your X800 but you might give it a shot.
3dbinCanada
Ted
I tried wiping down both sides of the 4K disc and went to the problematic chapters and it played cleanly through, no skips, no freezes, nothing. I will watch the 4K version again tonight and see if it plays through. If it does, I will cancel the return back to Amazon and will have saved some money on a new 4K player.
Doug2000
Doug
I'm having a freeze problem on 4K movies also. In my case I can usually get the video back on track after a few minutes of playing with the player's remote. I will try cleaning the disks - see if that helps.
Its a brand new player (LG Ultra HD UBK90) - I've only watched two movies on it - happened both times during intense scenes (deep into the movie) where, presumably, max energy is running thru the system.
Happened on Inglourious Basterds and Mission: Impossible- Rogue Nation (dont know if those are "three-layer" disks).
Could it be heat build up in the cabinet? It definitely gets a little warm in there.
The player is sitting below a 700 watt speaker amp:
img_9124-jpg.155755
Any ideas?
JohnRice
Bounded In a Nutshell
A Mile High
img_9124-jpg.155755
Any ideas?
Definitely try cleaning the discs with a microfiber cloth. That looks like a Class D amp, which probably doesn’t heat up much. However, is the Marantz a receiver or preamp? Receivers tend to get very hot. If it’s a receiver, you might want an A/C Infinity cooling unit.
Doug2000
Doug
Thanks.
Yes, the speaker amp is Class D. The Marantz is a preamp (AV7705).
JohnRice
A Mile High
Thanks.
BTW, you should only need to clean the discs once. There seems to be a film residue from manufacturing.
absplumbing
