Sony TA-P9000es 5.1 Preamp owners - I have questions? (1 Viewer)
J
John Morris
Other than the two 5.1 inputs, does this unit also have any stereo analog inputs?
Does this unit ONLY have a single 5.1 output and NO stereo output?
Are all inputs switchable as either total passive bypass or volume control only... or is the volume control always active?
Thanks for your help!
PomingF
Here you go John. The Sony has two sets of 5.1 inputs controlled at all times by both separate channels & master volume levels. It also has one set of 2 channel & one set of 5 channel 'bypass' that doesn't involve any of the unit's controls. According to the manual the 5 channel bypass is functional even with the Sony off but did not say the same for the 2 channel bypass. There is only one set of 5.1 output with no stereo output, as I recall.
I am using one set of the 5.1 inputs for my DVD-A/SACD player and the 2 channel bypass for my redbook CD rig.
PF
Grant B
here is the link to the TAE9000ES dicussion forum
there is quite a lot of info about the TAP, if you so desire
Link Removed
AKASGamingYT
