Sony TA-E9000ES upgrade
Discussion in 'Archived Threads 2001-2004' started by Richard J, Aug 5, 2001.
  1. Richard J
    Richard J Producer
    Sep 18, 2000
    2
    Hello forum members,
    I just my 2 year old unit of to Sony for
    the lastest,and greatest,improvements.Does anybody know what
    they are?
    Richard J
  2. Espen Braathen
    Espen Braathen Stunt Coordinator
    Feb 26, 1999
    77
  3. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    5,110
    Richard- Check out:
    http://pub7.ezboard.com/faussiedvdan...formationforum
    When you have a chance.
    If you sent your unit in to Sony, and the upgrade is free, more than likely you will get software rev 1.18. If you pay about $100, you should get a new (smaller remote, but much more useful remote) and rev 2.01.
    You can check the software rev by turning the +/- knob (I think it's this one) all the way to the left (I think!). It will say the rev at the very end.
    Also be aware, that there is an upgrade for the original crappy LCD remote. Improves the contrast a little, and allows the batteries to last much longer.
    Some people say that the sound has improved with each release (I don't believe that), but there are some functional improvements as well.
    As for the virtual 6.1 mode introduced by v2.01, all it did for me, was to push me in the direction of a real (homebrew) THX EX/DTS-ES set up by adding an external Dolby Pro Logic processor to my TA-E9000ES for the L + R rears, to add a center rear channel. Enjoy!
