Kelly Payne
- Jun 30, 1997
Hopefully, this is a quick one.
I got a T60 about a month ago and all is find and dandy. I had it hooked up using the standard stereo RCA's until the toslink cable I order came in. So then I (thought I) set everything up correctly and indeed I'm getting signal to my receiver and it's even detecting DD on the broadcasts that claim to be so.
The only strange thing is that I no longer get any of the audio from the Tivo operating system itself (the bing and bong noises when you navigate the menus). Is this a normal by-product of swithing between the two different outputs or is there a menu option that I missed somewhere.
Mind you, I'm not complaining about the situation, just wondering.
-Kelly
-Kelly
