Sony STR-DE945 Subwoofer Crossover Frequency
Discussion in 'Archived Threads 2001-2004' started by Rob Peloski, Jul 29, 2001.
  1. Rob Peloski
    Rob Peloski Agent
    Jul 28, 2001
    28
    Does anyone know what the subwoofer crossover frequency is on a Sony STR-DE945 when the speaker mode is set to "Large"?
    If I set the speakers to "Small" I can control it manually (down to 60Hz) but since my fronts go down below that I leave it as Large.
    The reason I'd like to know it is so that I can match the "Bass Range" setting on my Athena subwoofer to the crossover setting on the Receiver (right now I have it set to 80Hz)
    Rob
  2. JeffJN
    JeffJN Auditioning
    May 22, 2000
    3
    Perhaps I'm goofy, but if I remember correctly, ALL the Sony DE series receivers have a FIXED LFE crossover of 120hz, regardless of what size you have the rest of your speakers set at.
  3. Lee Bailey
    Lee Bailey Second Unit
    Jun 8, 2000
    263
    Central California
    Lee Bailey
    Rob, I have the STR-DE845, and can tell you that the sub crossover frequency is adjustable at 60,90,120,150Hz settings. You can also have different crossover settings for front, center and rear channels. Since LFE information being fed to your sub is up to 120HZ, you probably should be setting your subs crossover to it's highest, IF you are using the sub out jack from your receiver to your sub. If you are using the Speaker level inputs, that is, your sub is wired in first, then you connect your front speakers to the sub, then set the crossover where you want. In this case, leave the front set as Large, with Subwoofer set to NO. If you have a center channel and rear channel speakers that can't handle the lower frequencies, set them to SMALL, and choose the crossover frequency to the next highest frequency above the speaker's rated -3db low frequency is.
    I hope this helps...
    The Bailey's Web Page and Home Theatre
    The Bailey's DVD Collection
