Sony STR-DA5ES Transformation (1 Viewer)
Gerard Martin
Recently I asked your help in trying
to correct a problem I was having with
loss of ability to select PLII movie/music Neo6, my only option now is PRO LOGIC whereas the surround screen for the DA5ES should show
2CH Decoding
2CH Mode
C WIDTH and so on. My surround
screen now starts with PRO LOGIC.
2CH Decoding and 2CH Mode are strictly
for the DA5ES and PRO LOGIC strictly
for the DA3ES. Additionally my receiver
no longer displays 6.1 discrete another
DA5ES only. In effect my DA5ES thinks
its a DA3ES. Any solution to correct this. I have cleared the receivers memory, unplugged the receiver overnight, called Sony, Emailed Sony
no response, took the set into a local
authorized Sony service center and was
told there is a decoding or programming
problem but did not know how to correct it. The set is 45 days old so can,t take it back to the dealer, my only option
appears to be a regional Sony Service Center I don,t want to use unless absolutely necessary. Any ideas. Your
reply sincerely appreciated.
Warren_Sc
Did you try this: Sony DA5ES: DPLII Movie for TV and DPLII Music for CD! Plus other tweaks
I would not use the remote to set this up. In fact, maybe you should pull the batteries on the remote for a while. On the reciever menu, choose "normal surround" and then use the arrows and dial on the right to see what options come up. Make sure your digital connections are tight, too.
In the thread above I remember not being able to select DPLII Movie when I used the "normal surround" instead of "Cinema B".
Hope this helps,
Gerard Martin
Warren
I did all that, does anyone have other
than clearing memory a button reset
sequence to return this to a DA5ES. Perhaps something like a Sony secret
code that based on my experience with
Sony even Sony don,t know. Thanks.
Warren_Sc
I would go back to the dealer and complain. The dealer should handle this for you, in my opinion. If not, buy a new one there and swap the broken one.
Sounds aggrivating...
Gerard Martin
Warren
The set is no longer in the dealers
allowable return period, however I did touch base with him and he told me my best bet was to send it off to Sonys Service Center which I will do tomorrow. Unfortunately its in PA and I,am in FL.
However I do have backup a
Yamaha 7.1, Onkyo 7.1 and Marantz SR19
to carry me over. Thanks for your assistance.
