Charles Gurganus
- Mar 2, 1999
Thanks Randy. That was an interesting read. It shows you can't get away with inaccurate information on the net for very long.
It will do things the old 5ES can only dream of doing, no emotion here just facts, This does not mean the 5ES is a not good, on the contrary....it was ans still is great for what it does,its just technology is moving on!Could you please elaborate on the things the 5ES can only "dream of doing" that the 4ES does do? They both decode 7.1 (the 4ES has the 7th amp that the 5ES doesn't), they both do DD-EX/DTS-EX/ES, they both do DPL-II & DTS-NEO6.
Could you please elaborate on the things the 5ES can only "dream of doing" that the 4ES does do?For example:
- dts 96/24
- "Real" Dolby Digital EX. The 5ES will decode a DD-EX soundtrack, but it uses Sony's DCMD decoder, not Dolby's. DD-EX lisences were not available for non-THX equipment when the 5ES was designed.
- Analog downmixing. Avoids truncation of the digital data when mixing channels together digitally. Also allows the 5.1 inputs to be downmixed to 5.0 in the analog domain (for systems without a sub, like mine).
- better EQ in the surround and surround-back channels (the 5ES lacks the "mid" band).
- Improved accuracy and less noise when decoding surround formats by using Sony's newer decoder DSP, the CXD9718 (vs. the CXD9717 used in the 5ES.)
- Digital Concert Hall modes are now 7-channel.
- use of all 7 channels with 5 channel surround sources.
- 12 V trigger
- IR repeater inputs/outputs
I didn't list specs; I listed features. Someone asked for a list of things that the 4ES does, which the 5ES can not do. That's what I tried to present.not said:Quote:
Really? How would you take the 5.1 (DD, dts, DPL-II) decoded internally and make 7.1 out of that for the 5ES? Can't be done.Sure it can. Get an external 2 channel amp with 2 inputs and connect both the rear and sides pre outs to the amp. When you're watching 5.1 sources set the amp so that your rearmost speakers put out the same thing as the sides. With EX and ES set the amp so that it outputs the extra 2 channels from the DSP.
Seth
didn't say that either one was better, just that the 4ES can do it Dolby's way (and has the logo on the front as well). Sony's DCMD can be used (by turning 6.1 decoding to "on" instead of to "auto") for either dts or DD extended surround modes, so someone at Sony must have thought that someone may want to choose it over the other decoders.The Sony DCMD that Sony uses conforms to the DD-EX specs so there would be no difference in decoding from one to the other. If this was not the case the DA5ES would NOT have been allow to have the DD-EX emblem on the receiver, as well as the DLP-II. It also has the DTS-ES, DTS-NEO6 emblems as well.
The Sony DCMD that Sony uses conforms to the DD-EX specs so there would be no difference in decoding from one to the other. If this was not the case the DA5ES would NOT have been allow to have the DD-EX emblemNo 5ES I have ever seen has the DD-EX emblem on it.
Check out the pics of the 5ES at Crutchfield and compare that to those of the 4ES which proudly displays the DD-EX logo, in addition to dts-ES and 96/24. Of course it is entirely possible that they have updated the front panel silkscreening since the time that those pictures were taken, so more recently produced units may have that logo. The one in my local Sony Store's showroom does not.
Sony's DCMD decoder uses a similar methodology to decode the 3 surround channels from two, but (probably) does not use the exact same algorithm. That's why the user can choose either DCMD or the Dolby/dts one.
