AaronBatiuk
- Aug 23, 2002
Gil D said:
Note that Sony's DD-EX and dts-ES receivers offer something that no others do: Sony's proprietary surround-back decoder. The selection of the decoder is based on the 6-channel mode that you use. In "Auto" mode, Dolby's or dts's surround back decoder is used for their respective (6-channel flagged) sources; in "ON" mode, Sony's decoder is used. It is left as an exercise to each listener to decide which does a better job.
If the 4es operates similarly to my DB830, then you can get bass management (i.e. sub low-pass and front high-pass) with 2 channel analog or digital sources. Simply put the receiver into AFD (Auto Format Decode) mode, as opposed to 2-channel mode (which is truly only 2-channel - no sub). If you have set up the receiver to use a sub *and* set to "small" front speakers, then you will get bass redirection in AFD mode when listening to a 2-channel source, just as you would when listening to a multi-channel source. If you use 2-ch mode instead of AFD, you lose bass redirection, but keep the EQ. If you use the analog direct mode, you lose all processing including EQ.The 2 multichannel inputs on the Sony are nice, but I'd like to see some level of pseudo bass management on the stereo inputs like on the Denon
Yes, dts NEO:6 is dts's answer to Dolby's DPL-II, and both are useful for multi-channel music reproduction from stereo sources. Both have a Movie mode for matrix-surround encoded sources and a Music mode for non-matrixed sources.Is Neo 6 the 5/7 channel stereo equivalent - I'm not sure. At least there is DPL-II.
