sony sawm500 problems...help
Discussion in 'Speakers & Subwoofers' started by joe_, Jul 3, 2005.
  1. joe_
    joe_ Auditioning
    Jul 2, 2005
    4
    i had the sub hooked up via speaker wire to my old htib system. yesterday, i bought a new jvc dvd player with an rca out for the subwoofer. got it home and unhooked the speaker wire and plugged in the rca cable and got no sound. i would turn the sub off then turn it back on and get sound for about 3 seconds. the sub would then click and the power light would stay on, but no sound. i tried hooking it back up to the old system and its doing the same thing. anyone had this problem or know a fix? thanks in advance for any help.
  2. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    If I understand you correctly, you connected the sub directly to the DVD player. This will not work. The signal needs to be passed through a receiver or preamp stage first to handle volume and x-over settings (as applicable), so if your receiver does not have a sub pre-out, you'll have to go back to your previous setup. If it does, then you can connect the player via analog or digital to the receiver and use the receiver's sub pre-out.
  3. Clinton McClure
    Clinton McClure Casual Enthusiast
    Jun 28, 1999
    4,544
    469
    4,110
    Central Arkansas
    Clint
    Joe - If the DVD player has RCA outs on the back for r/l mains, center, r/l surround and sub, these are analog preouts and must be connected to a receiver or preamp. As John said, they will not work and may damage your speakers if hooked directly without processing.
  4. joe_
    joe_ Auditioning
    Jul 2, 2005
    4
    sorry for this misinfo, the dvd player has a reciever built into it. it like a htib without the speakers. actual model is a jvc rx-dv31.
  5. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    In that case, you probably need to look at the unit's speaker setup and tell it sub=yes, and set the rest of the speakers to small. Hopefully it will be as simple as that.
  6. MichaelPR
    MichaelPR Second Unit
    Nov 16, 2003
    401
    I had this sub and moded the hell out of it! Not bad for the $75 I paid for it....but man is there nothing like an SVS
  7. joe_
    joe_ Auditioning
    Jul 2, 2005
    4
    i turned the sub on in the dvd menu, but what i dont get is that even the old system it worked fine on is producing the same results. sound for a couple of seconds and then it kicks off. i have to turn the sub off and wait a few seconds and then turn it back on to get it to work for a couple of more seconds.
  8. brendy
    brendy Agent
    Apr 26, 2005
    45
    Since it's doing the same thing on both systems try checking out the sub itself.
  9. joe_
    joe_ Auditioning
    Jul 2, 2005
    4
    what do i check? the only switch on the sub is the phase switch (normal or reverse) and controls for the gain and freq response.
