sony SA-WM500, upgrade of WM50??
Discussion in 'Speakers & Subwoofers' started by kuttaS, Jul 28, 2003.
  1. kuttaS
    kuttaS Stunt Coordinator
    Jul 21, 2003
    111
    everyone reffered me the sawm50 for JBL NSP but when i was looking for it on sony's website, i saw the SA-WM500 for simimlar pricerange. is this the updated version of wm50 and tell me how is it compared to JBL PB10
  2. Chris Elm
    Chris Elm Stunt Coordinator
    Mar 30, 2003
    120
    Hi. If memory serves me correctly there is no such thing as the SAWM 50. Sony had two models: the SAWM20 (8 inch) and SAWM 40 (12 inch).
    They have since been discontinued, replaced with the newer designs (including the newer 500).
    Some say that it is actually a step back in terms of performance, but I wouldn't know from personal experience.
    I do however recall the older wm40 having a better lower extension range as per the specs.
    I had the 8 inch model before getting an SVS.
    Hope this helps.
    PS. You should still be able to find a WM40 online for quite an attractive price.
