Sony SA-WM40 Subwoofer
Discussion in 'Archived Threads 2001-2004' started by Oscar_R, Dec 18, 2001.
  1. Oscar_R
    Oscar_R Second Unit
    Nov 1, 2001
    341
    I'm on a limited budget after purchasing a Denon 2802 and was considering this sub.
    http://www.sonystyle.com/electronics/prd.jsp?pid=6596
    Anyone have any experience with it? Any comments or better suggestions would be greatly appreciated. Also any comments on the virtues of front firing vs. ground firing would be greatly appreciated.
  2. Vasanth B
    Vasanth B Stunt Coordinator
    Aug 18, 2001
    61
    Though the search may have been disabled when you posted, a search for "Sony Subwoofer" will yield you a lot of good posts discussing this sub. Read them.
    This is pretty much the best woofer in it's price class (less than $200) but you certainly can get a better sub with more money. If you get this as a starter sub to build your home theater, I think you will be pleased as long as you properly calibrate it. Additionally, you should find some posts on how to upgrade the sub with poly-fill to improve the bass response.
  3. DaleI
    DaleI Stunt Coordinator
    Jun 5, 2001
    128
    Limited budget or not, this is a fine sub for a home theater. Just calibrate it correctly.
