sony remote control problem
Discussion in 'Archived Threads 2001-2004' started by tom_furman, Aug 12, 2001.
  1. tom_furman
    tom_furman Stunt Coordinator
    Sep 6, 2000
    174
    ok...i've had my db-840 for 6 months or so and just recently bought some bass shakers. so i hooked up my old sony de-375 pro-logic receiver and hooked up the bass shakers to it. everything worked fine. and then while i was watching a movie i tured up the volume on my db-840 and fet the bass shakers start ro rumble alot more! so i get up and look and sure enough...my emote for the db-840 is turning up the volume for BOTH recivers!!! is the frequency that same? do i have any options to "change" it?
  2. Doug Samsel
    Doug Samsel Extra
    Mar 10, 2001
    15
    Sony has two or three different code sets for there receivers, but as far as I know there is no way to change which codes they use. A work around would be to put a piece of electrical tape over the infared receiver on the front of the receiver connected to the base shakers.
