AaronD
- Dec 4, 2001
I've been looking for that perfect pocket size device to take on walks and to work for casual listening. I started out looking at small mp3 players with either memory cards or 3" cd's for their media. For some reason Sony's new NetMD portables never popped into my head, until I went to circuit city to pick up a DVD or seven. Needless to say I walked out of the store with a NetMD MZ-N505 ($149.99) and a five pack of MD's.
Here are my initial impressions.
Specifications
The MZ-N505 isn't anything special in the hardware area. It sports a USB connection, a Optical digital in, Headphone Out, A Control Port, and a DC in for the supplied wall adapter. In addition, the MZ-N505 has MDLP capabilities which is the reason for the lofty play times listed on the packaging. The device supports the following ATRAC compression levels.
1. Standard - ATRAC3@132kbps - 80 Minute Play Time.
2. LP2 - ATRAC3@105kbps - 160 Minute Play Time.
3. LP4 - ATRAC3@66kbps - 320 Minute Play Time.
Ergonomics:
The size of the unit is exactly what I wanted, something that would fit in my pocket and stay out of the way. The controls are very easy to understand, but I would like to see a back light on the small LCD for low light situations. My only complaint so far is that the volume buttons are too close to the directional pad that controls the play functions. But, this is definitely not a show stopper.
Software:
Perhaps the coolest feature about Sony's NetMD devices is the supplied software. OpenMG Jukebox and NetMD Simple Burner are the included packages. The Jukebox software is meant to "manage you music collection" including the hordes of MP3's you may or may not already have. The included "NetMD Simple Burner" is for quickly copying CD's direct to mini disc. But beware, this setup does have DRM so if that sort of thing makes you want to scream you have been warned.
The included Juke Box software stores files that you've ripped from CD in the ATRAC format with a bit rate of your choice. When ripping from a CD you can choose to send it to your hard drive or your hard drive and attached MD player. Not only does it manage the ATRAC files on your hard drive but it keeps track of your MP3's and will convert them to ATRAC and send them to your NetMD device. In addition you can edit the contents of an existing MD and even download it to your PC. For those of you who have stand alone MD recorders in you systems this device would allow you to change track/md titles and re-order tracks all with the luxury of a keyboard and GUI.
Regardless of what you are transferring to MD you can choose between Standard, LP2, and LP4. In my tests I transferred from CD and MP3 to NetMD in both standard and LP2 modes onto the same MD. I really like being able to mix bit rates on MD, and was able to fit one full album in Standard (from CD) and a second in LP2 (from MP3).
The NetMD Simple Burner software is great for quick copies to MD, however for some reason you can only choose between LP2 and LP4, standard (or full bit rate) ATRAC is not available. Whereas transferring full bit rate ATRAC in the juke box software could take some time (around half the play time of what you are transferring), copying a CD using LP2 is very quick. It took me around 10 minutes to copy a ~45 minute CD. Both software pieces integrate with CDDB for automatic naming of tracks and albums and the Simple Burner also automatically creates groups with the corresponding album name on the MD.
Sound Quality
The included headphones are definitely not something to write home about, but they aren't totally bad. My biggest complaint about them is that they are stiff and hurt my ears after extended wearing. I whipped out my Sennheiser HD 570's for a listening test instead. The CD I had copied to Standard ATRAC on the MD sounded very good, it was perhaps lacking a little bit in the highs and was a tad murkier. BUT, the overall SQ was very good considering the device and application. I then listened to the MP3's (128k) that I had transferred to the MD at LP2. With the MP3's I honestly couldn't tell that much of a difference between the two. Now, I'm not an advocate of MP3 for sound quality, just mostly convenience...But I don't think I'd have problems with recording 160 minutes of audio to an MD to lug around with me.
Final Thoughts
NetMD is definitely cool, and I like it much better over the MP3 players I was looking at. I think ATRAC sounds better than MP3, and MD's are way cheaper than memory cards and more rugged than 3" CD's. The included software is pretty nice, if you can get over it's DRM quirks which aren't that bad to begin with. I think a NetMD device would be a welcome addition to even a seasoned MD lover, if not just for the ease of copying CD's and MD's and editing with a GUI.
I can definitely see a MD deck for my car and HT by the end of this summer... Perhaps the proliferation of MP3's and small portable devices will be a saving grace for MD after all.
Thanks for listening!
-Aaron
Specifications
Ergonomics:
Software:
Sound Quality
Final Thoughts
-Aaron
