Grant B
- Mar 29, 2000
Most MChangers have only an optical digital output. I have 2, so the only way to use the shuffle play was to use the analog output
My preamp has both an optical and coaxial input options for the "cd input"
I used a parts express optical to coaxial converter (~$18)on one and ran that into the cd input; then I ran the optical from the other also into the cd input. I then set it to auto detect; now i can shuffle play without using the analog outputs, which bypasses the cheap D/A in the changers.
